APX 4500 3.5mm Audio
RTmed519
Earlier this year I posted this thread regarding APX audio output via 3.5mm. One of the members here posted the exact link I was looking for, but I'm at the point where I'm looking for a similar cable available to APX 4500 mobile radios. I need a cable that will output to 3.5mm, which I can plug into PC's to feed audio. This will be feeding encrypted audio, so a scanner is not possible.
I've done a few google searches and turned up nothing. Does anyone have any ideas?
jeepsandradios
East of the Mississippi
I have not seen on made commercially yet. What I have done is take the accessory cable and add a wire for audio. Pin 21 is filtered audio which is a set level. You need ground from Pin 14. Put what ever flavor of connector you want on the other end. I normally terminate to an RCA as they are feeding an amp. You can grab the pins on ebay or other MSI sources.
RTmed519
ramal121
Lots and lots of watts
Calif Whine Country
Not required to use but if there is a power outage you'll have to manually switch on the radio again with the power button. With ignition sense and program set to Soft Power Off the radio will automatically come back on.
