APX 6000 programming
BPier
Hello. Newbie here. Just promoted to a new position and now am responsible for about 400 portable and mobile radios. Before the previous guy left he purchase about 45 APX 6000 radios. Before that we have used mostly XT 2500 portables and maybe about 30 APX 4000 radios. I was familiar with cloning radios and could do that and then add them to the system using Provisioning Manager. Problem I have now is trying to get the 6000 to work. I have programmed one of the new 6000 by setting it up by looking at a 4000 codeplug and setting everything the same in the 6000 codeplug. Added radio in PM and 6000 can receive but when push PTT button only get an alert tone, not able to transmit. What am I missing? Any thoughts would be helpful.
nikronzo
4.X SloppyCast
there is a lot of missing info here dude, is this conventional, trunked? analog or digital? what band are we discussing?
i get it, your a newbie, but if you are going to be a radio sysadmin, you need to know every inside and out of your system and radios...
ME801
NV
Sounds like its not added to the system. I'm assuming its TRS.
xmo
If you have access to PM, you should also have access to tools that will show you exactly what happened when you pushed the PTT button.
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
That's assuming the radio is actually seeing the system. Some people turn off all OOR indicators so you don't know if you're out of range.
But yes, ATIA data and a parser might give you an idea of what's happening if it is actually seeing the system.
ME801
NV
I feel the OP's pain, I was voluntold I was the new SysAdmin. He should be able to see the radio. If it's affiliated and receiving, I wonder if it's set to RX only on that TG.
NVAGVUP
You are in deep water. (Trunking, APX programming, Provisioning Mgr, etc)
A hobby site is not the right place to throw a lifeline. Find a reputable shop/admin to help mentor you on this one. (I am not telling you this to be a d!ck. I am telling you this as someone who deals with APX programming and trunked systems)
