APX 6000 Side Buttons
csimpson911
East Central Mississippi
I'm programming APX 6000 radios using CPS Version 22.00.01. I want to program the two side buttons below the PTT button. When I pull up CPS buttons in the menu and the option to add the function of zone up and zone down is marked red. What am I missing, I know I have something clicked/activated somewhere else that is preventing me from making this function available. I do have zone up and zone down listed in the menu, but even when I take it out the option is still not avaliable. What am I missing? I'd like to get these radios inline with the EF Johnson radios we are using. Trying to keep the radio buttons all inline. Thank you for any help.
csimpson911
Check your ABC switch or other button switch. You are correct. The radio will not accept the function if radio has function programmed in another location.
I found the problem...I changed the conventional side to zone up and zone down. Once I did that it made the buttons work on the trunking side in the same manner. Still learning all the little intricacies of CPS. Thanks for your help.
GTR8000
NY/NJ Database Guy
BEE00
Are these AN or BN model 6000's? And do they have Enhancement Level 2 in the flash? Aside from the menu items, is anything else assigned to a Zone function, such as the ABC switch?
GTR8000
NY/NJ Database Guy
BEE00
I see that you edited your post as I was typing mine. Yes, some functions need to match conventional vs trunking in order to be valid selections.
csimpson911
I appreciate the response, I'm sure the more I work with CPS the more I will probably post questions. I use the Armada software for EFJ radios daily, but we have received some M radios and am working on learning CPS. Thanks again for your response.
