I have it setup as Standard. You’re right, no guarantees, I was just hoping it would work since it’s newer technology (QuietComfort)Do you have the BT set to "LF MPP and Standard" in Radio Wide options in CPS. Keep in mind, not all COTS headsets are compatible. There is no "list" of consumer compatible devices. Some work, some don't. The only GUARANTEED compatible devices are Motorola Mission Critical BT devices.
Ok thanks for that. It’s saying “failed to connect” so maybe it’s user error right now lol!The radio will display BT profiles not supported after Pairing in progress... if the device is not compatible.
They were, to two in fact.Make sure that the headphones are not actively connected to any other device before pairing with the APX.
Do you know any that work for sure that are not Motorola? I don’t think Moto offers a non RSM Bluetooth headset only, do they?my experience is that COTS devices are hit or miss with APX radios.
I've gotten my LG HBS-750 to pair just fine. It's a crapshoot as to which will work and which won't.
I have a Plantronics M70 bluetooth earpiece paired to mine. But I had to clear all other pairings from the radio before it would pair.
They are very picky as to what they will and will not pair with. I have a thread on this somewhere in this section. There are apparently a lot of COTS Bluetooth equipment out there that they don't want to pair with.I have it setup as Standard. You’re right, no guarantees, I was just hoping it would work since it’s newer technology (QuietComfort)
Yes I was able to set it up over the weekend. Bluetooth programming is so much easier than using the cable!Assuming you have the bluetooth board, once you've connected your radio and computer together change the Communication Method to Bluetooth
