APX 900 radios
P25Radio
Oceanside Ca.
I have noticed some FD and Life guards are using them, kinda new to me are they any good? Do they hold up?
Ravenfalls
Yes they are durable & waterproof. Motorola warranty is a flat rate repair or exchange depending on contact terms.
Anderegg
Enter text in this field
San Diego
They are basically XPR7000 MotoTRBO radios flashed for P25 TDMA. I have heard the antenna connectors and vol/ch pots snap off pretty easy vs the 4000+.
Paul
PACNWDude
+1 on the volume/on/off pot issues, as well as some build quality problems on the PTT button bezel (you have to recase the radio when that breaks, which is common). This is the case for all of the APX line though, PTT button bezels tend to crack, and like similar constructed XPR radios (XPR7550/e for example), a new case is needed, or some super glue can help until a new case is available or needed.
APX900's are decent radios but they lack the dual microphones of the higher model APX4000, so they are good if the end user is NOT in a high noise environment. For forklift drivers, machinists, or any users in high noise areas (HVAC, possibly firefighters with pumps and water spraying around) I would highly recommend the APX4000 instead.
