APX Bootloop
Mboy00
Aberdeen Township
Starting off, I would like to first start by saying the radio is NOT inhibited. Confirmed this with the system admin.
Radio is an APX8000, R29 Firmware, Codeplug V32.
Has anyone heard of this happening in a bootloop before? If so whats the best option to solve this? Sending it back to depot?
N9JIG
Sheriff
Moderator
Far NW Valley
Give it to the System Administrator as he would have the proper System Keys and software to update and program the radio properly.
mbnv992
Also known as MT2000 man on Batlabs since 2001+
AZ
Firmware R32.03.00 fixed the boot loop issues.
chrismol1
Was the radio recently programmed? The recent well known bootloop issue was officially recognized as being a problem with firmware version 31, often not occurring until it happens, which this radio does not have so makes it more unusual but not totally unheard of that a radio of any age or version would develop an issue, things happen. Maybe it has something to do with a corrupted codeplug if a hardware issue is not at play. The bootloop issue is typically something a regular end user would not be able to fix on their own requiring depot servicing.
SCFDCOMM
We have some radios which had the firmware referenced above installed, and a month later they went into endless loop.
It's possible they were upgraded, and not used or turned on for that time period.
As said above, it must be sent to depot for resolution, there is a bulletin about it
MTS2000des
5B2_BEE00 Czar
About to send in a BN 6000 that was out of warranty when it started boot looping under the MTN. Hopefully it will be covered. Officer was out on maternity leave and radio was off for the past 6 months. She took it out of the charger and bam- "Motorola Solutions" endless cycle. Per our records it was at R29 when it was last used.
MatRat80109
Colorado
MTN-0149A-23 addresses a power cycling bug.
"APX radios that have 2023.2 Firmware / R31.xx.xx (R31.00.00 thru R31.02.00) may enter a continuous power cycling condition. This affects APX series P25 radios, N30, and N50. Next series and N70 are not affected. Radios affected by this issue must be sent to Motorola Depot for repair referencing the MTN."
Not your reported FW but pretty close.
MR
Asunakiyori
Lurker
Hiding in a Shed somewhere
MR
when you say N30 N50, exactly where would i find that on my unit. my FW is r31.00.00 2023.2_feat
GTR8000
NY/NJ Database Guy
BEE00
Well, do you own an APX N30 or APX N50? If not, then you won't find it anywhere on your unit.
