APX CPS 35.00.00 - MULTIPLE CODEPLUG SUPPORT ADDED
PACNWDude
The HARRI$ AN/PRC-152(C) had multiple mission plan file capability back in 2005. Those could have 30+ mission plans depending on the size of each mission plan file.
As well as the XG-100P Unity handheld.....multiple mission plans were great.
ElroyJetson
I have to admit, mission plans were a great idea. I've got 10 loaded into my XL200P. That's the limit.
I did this to evaluate how or if the radio's functions slow down with the memory getting full with more plans loaded.
In terms of quick response to inputs, the APX makes a fool of the XL. It can take over six seconds for a control input on an XL to be completed. How that's even acceptable for any critical duty is beyond me.
PACNWDude
+1 on R35 being stable as found so far. Had to upgrade for a new APX8000XE being programmed for a test with an Aero Connect RT-7000 (with APX8000 module). Had to have several systems and 126 analog channels VHF/UHF R1/UHF R2/7/800 Mhz loaded for testing for interference with other hardware.
Codeplug was stable, and worked well on Del running Win10 Pro at least. 3 codeplugs in my use case.
Joseph7376
Savannah, Ga
I have a APX8000 for personal how do you add this feature by chance I aslo have a xg100 and i like the idea of having misson plans
KE4ZNR
Radio Geek
Read Post #2 of this thread:
And now the fine print:
  • It's going to cost you at least $138 to add the feature to the FLASH, assuming the radio is supported
  • Only BN "Enhanced" or 8x00 models are supported (as well as NEXT/N series); not supported on legacy AN or 7x00 models
  • Requires a model 2.5 or 3.5 portable, not supported on 1.5 models
You gotta purchase it from Motorola. It is not a free option.
Joseph7376
Savannah, Ga
I saw the post, but didn't explain where to go to get the feature added. I don't have an issue paying but finding a dealer is the problem, and good thing the radio isn't bought "FB Marketplace or Ebay."
Outerdog
T¹ ÆS Ø
Nobody here really has an answer for this, so they'll just hit you with the snark instead.
TDR-94
In this case it's multiple 'codeplugs' for the APX8000. Mission plans are a carry over from the L3H RF Division, tactical radio side of the house, from which the XG-100P originated. The same terminology was carried over as a result and is still being used with the current line of XL radios.
Military operations tend to be dynamic and radio programming may require different configurations for each specific mission. So for added flexibility many of the L3H tactical radios had the ability to have multiple 'mission plans' stored in the radio.
