APX APX Decode MDC Trailing Edge
Jl942264
Any special reason you have 2 accounts?
Yes actually, I lost access to the email in which I created my first account and could not reset my password so I was locked out. Upon gaining access back I managed to reset my password in the meantime I created another account. I’m unsure of how to delete an account if I knew I would have already. Wasn’t aware you couldn’t have more than 1 account….
WRTF671
Got it working don’t ask what I did… I changed the IDs on both radios and boom
I just ran into this too! I had two APX 8000s that would not display IDs no matter how hard I tried and an XPR that had no issue displaying. I finally figured out I had the same ID in all three radios and for whatever reason that prevented the APXs from showing the ID but not the XPR. I reprogrammed all three with unique IDs and everything works now!
Rudy3145
New York
Im having same issue. APX8000 and 7000 wont read MDC ID. Set to Dispatch and Scan PTT Display enabled. I've tried everything.
WRTF671
Where are you trying to read IDs from, each other or from something you're scanning?
GTR8000
NY/NJ Database Guy
BEE00
And you're using unique ID's for each radio, right? You have PTT ID checked for the personality? Go back over this thread and read every post, the info is there.
WRTF671
This. Check your IDs, if they're the same you will not see a display. As much as you might think it's funny to have B00B5 pop up when you key up (there is a true story behind that...) you can only have one radio do it at a time...
Rudy3145
New York
wow that's strange. Both APX will read a radio MDC ID from an XPR though
WRTF671
Read what this guy wrote...
Rudy3145
New York
it was because both apx had same ID. strange. thanks for the tip brother!
k4tdo
I have had the same problem with 70 APX 4000s, yes 70 Brand NEW ones displaying the MDC IDs from other radios. The EOV set to 2 seconds fixed my problem. Now to clone them all with their unique IDs.
