APX no-affiliation listening
Baker845
anywhere
Does any one have the instructions for setting up the apx 7000 radio for no-affiliation method on p25 Uhf
trunking system?
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
Have you read the instructions at communications.support? It does work. Safest way for me was to use my channel knob as zone select and then put the trunk zones in zone 17, 18, 19, etc. That way as long as I didn't have a zone button programmed I could never accidentally switch to a channel to affiliate. I just reference the talkgroups I wanted to hear in the scan list, which was easily edited. I had zone 16 as my scan zone and then used RX only conventional channels as my scan list placeholder channels.
I found I preferred to stick with the zone knob because I typically sat on one channel all the time anyway, and I set the left and right soft buttons as CHUP and CHDN. It also made more sense since I could have more than 16 channels in a zone. And with last channel/zone checked, I didn't have to scroll the list every time I switched zones.
Baker845
anywhere
I can't get on that web site so I thought I ask here. If some one could pm or email me the instructions that would be great.
trunking system?
I've had no problems at all when it comes to 800mhz systems. But when it comes to UHF, I've never been successful.
If you find a way, PLEASE, do share.
Thanks so much!!
Paul
riveter
MD
Same exact procedure between UHF and 7/8, just different bandplan and CC frequencies...
Not sure why that wouldn't work, I got it going just fine.
Still having the issues. Just tried again, with no luck. I have the Astro 25 channels loaded; the correct control channels; etc etc etc. Nothing working for me when it comes to UHF.
Very frustrating indeed.
Thanks.
Paul
KevinC
Other
Super Moderator
Home
Thanks.
Paul
Not much help, but I do it on several P25 UHF systems with no issues at all.
Are you 100% positive the bandplan is correct?
redbeard
BEE00.348-3.1
Same here. It's all about the bandplan. If you haven't edited it, or know what we are talking about, that is the problem.
Also http://communications.support works fine for me. If you "can't get on that site" you have issues OP.
KevinC
Other
Super Moderator
Home
Let's keep this about the original question and not about the CS website.
riveter
MD
Sniff it with a traffic analyzer.
RTL SDR and Unitrunker/Pro96Com works well.
