APX Pre Amp
cpg178
I have a 7500 in VHF/UHF1 with the preamp option enabled. From what I understand from the help files once I enable the main pre amp check box I then have to go into each personality and adjust another setting but I can not seem to find it. Am I missing something here?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
The help files have hyperlinks built in and you can click on the link to take you to the setting:
cpg178
Correct which is why I referenced the help files in my OP, when Pre-Amp is enabled under Radio Wide there is no RF AGC option on any conventional personalities. I didn't see any other forum posts about it so figured I would try to gain some insight here
cpg178
This is what I see on a Conventional Personality, my CPS (R27) Help files actually do not have hyperlinks, so I am unable to click the RF AGC text in the help window. There is an advanced RF AGC option like in your picture but I can only see that if I was to click on a trunking personality which I do not utilize. Is it possible that my FW needs to be bumped up, I am at R15.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I just opened an R15 firmware codeplug in R28 CPS and the option is still there. Are you sure you've got the Preamp option?
I wouldn't worry about it too much. If you read the help files on Advanced RF AGC, you're really only changing that setting on channels with intermod issues.
cpg178
Yes, I have W12 enabled. I had read about that in the advanced field, I had figured the pre amp function would bring in a few weaker signals from what I had read on the forums here but it appears it is just for fixing intermod.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Yes, it does bring in weaker signals. The AGC setting is if you experience intermod.
cpg178
From my research the Pre-Amp was standard hardware on every XTL radio so I would guess the same for APX? Still not sure if the pre amp even works on mine as this 7500 replaced an XPR5550e and in some spots I am getting worse RX than I did before (antenna setup is unchanged). I figured it would do better than not worse and this radio was very recently autotuned with an aeroflex
AustinBodurian
Xpr is a damn good receiver
