APX RSM Issue
Jl942264
Hello all, I have an APX7k with a HMN4104B microphone that is giving me no audio. The microphone and screen are working flawlessly. I just have no audio coming out. Any help is appreciated
GTR8000
NY/NJ Database Guy
BEE00
Have you tried the mic on a different radio? That would tell you pretty quickly if you have a bad mic, or something is wrong with the radio itself. Is it just the RX audio that's not coming through the mic? What about TX audio, is that making it through?
Jl942264
Yes, tried it on multiple radios the mic is functional only RX audio isn't making it through. TX audio is all good!
GTR8000
NY/NJ Database Guy
BEE00
So the mic is partially functional. It displays the same behavior on any other radio you connect it to: no RX audio, good TX audio?
Try replacing the mic cord if that's an option for that model, otherwise it may be time for a new RSM.
Jl942264
No, the mic is fully functional on another APX. I was wondering if I was missing something in CPS
GTR8000
NY/NJ Database Guy
BEE00
Gotcha. It could be something in the codeplug, or it could be a physical issue with the radio that is not sending audio to the mic through the accessory connector. Have you tried a different mic on the same radio, and does it behave the same way? I'm going to assume that with the mic detached, the audio comes through the internal speaker just fine?
ResQguy
Meh
Depending on how you set up the code plug, you may have to try turning the volume up with the rocker on the RSM. There is a checkbox to disable the radio’s volume and channel controls when an advanced RSM is attached.
Jl942264
Yes, every mic I've connected does the same thing. And yessir the audio comes thru 5x5
what would be wrong in the codeplug....some typical places to look
GTR8000
NY/NJ Database Guy
BEE00
Check the setting @ResQguy mentioned, it's called Volume Lock with Acc or something like that, under Radio Ergonomics Wide. I assume that you have already tried both the radio's volume knob as well as the RSM's volume rocker, with no success. Are you getting any audio out of the RSM, such as power up beep, scan on/off tones, etc.? Or absolutely nothing at all?
Jl942264
Nothing at all, even with both of those settings checked.
K2NEC
5F6
How does the condition of the pads on the accessory connector look? Do they appear damaged at all?
Jl942264
Very good, radio is in new condition clean and not pitted
K2NEC
5F6
Did you get the radio from a dealer? If so, it might need to be sent out for repairs because it sounds like it might be an issue with the connector itself.
Jl942264
Yes I did just wondering if I missed something.
dgruver911
Newton, KS
Make sure in the Zone config that the profile isn't set to surveillance 1. That will kill a speaker mic if attached. Been there done that....use default or if they have to have a quiet mode with no lights and tones use surveillance 2 it won't kill the RSM audio.
Jl942264
It’s set to default im going to try to create my own profile and see if that helps.
Jl942264
Tried all of the things above anyone have any other suggestions!?
Tech21
take the codeplug from a known good radio and clone it to yours. You know the mic works when connecting it to a different radio. I am assuming the other radios are programmed the same. If not, save your codeplug and write theirs to your radio temporarily and then check the mic again. If it works, it's a codeplug issue, if it doesn't, it's a radio hardware issue.
Jl942264
Update: Radio came from a Fleabay vendor, (not my radio) had to go out to M to get fixed. FUBAR inside PCB board had water damage and ribion connectors were a mess. Thanks all!
