APX900 Encryption Loading
APX8000XE
Classified
Hello,
I just got a APX900 that has software AES/DES, I have no experience with "software encryption". I attempted to load keys with a KVL3000+ but was unable to, do I need a newer KVL? Is the loading done in the software?
Thank you
quebecradioguy
Quebec Database Admin
St-Eustache Quebec Canada
Hello,
Thank you
I Believe since it's software encrytion, you put in the key in the secure section in CPS, like you would do with software ADP
N4DES
Retired 0598 Czar ÆS Ø
South FL
3000+ will not work. You need a 4000 or 5000 to load them, and the 4000 needs to have updated FW to accomplish this as well.
You will also use the USB programming cable to load the key and not the typical KVL cable that you are used to.
APX8000XE
Classified
Ok, thanks. I do have access to a 5000.
