Problem Still Exists
RISC777 said:
So, hotdjdave, did you get this figured out ?
What system, or is it all regardless of 'type?'
It is only the systems to which I make changes. The problem has been occurring only within the last week or so (after using it with no problems for a month or so).
If you ask me, I think it is some sort of built-in thing that happens when the trial version is supposed to end...however, mine has not yet ended (at least I have not yet gotten any messages).
I did get an expired message when I downloaded the newest trial version of ARC396 PRO, immediately opening after installing it. But when I open the older version, it does not give me the error.
I have gone back to using the UASD software for now. I did want to try out the newest version of ARC396 Pro to see of this problem is in that version before I purchase it...but I guess that will not be possible. I will just wait to see if there are any problems brought up in the forums and groups. The UASD software did not have any problem after uploading the rewritten data to the scanner.
Butel told me that my trial version should have been enough time to figure out if I want to buy the program, but when the problem starts right near the end of the trial, then how is one supposed to know if the newest version is any better without trying it first (which I cannot do because it immediately informs me that the trial is expired and that I cannot upload data - which is what I need to do to see if the problem still exists). I guess it is a catch-22 situation. I spent about two hours tonight fixing the errors in both the ARC files and because I saved the systems in the UASD software before I discovered the problem, I had to fix that data as well. It was not as hard as I thought it would be, but still! ARC format is not the same as UASD format (ARC is freq and name, UASD is name and freq) making it somewhat tedious to copy and paste.
Butel has not been any help, either, in this matter. They tell me that my version is old and expired and that I cannot use a newer version. What the heck am I supposed to do? It is not like I am trying to get another free trial (extended freebee), I just need to see if this new version has the same problem. There HAS to be a way to remove ALL of Butel and ARC files off of my computer and be able to download a new trial version without it telling me it is expired. Butel software has to have put some hidden file on my computer for the software to know that the trial version is expired. Like I wrote, I have removed every instance of Butel and ARC from my computer and Windows registry and the problem still occurs (the 0.0000 MHz and the expired message). Being so, how would the Butel software know it is expired (even after just downloading it and removing prior versions, files, and registry entries from my computer)?
Don't get me wrong, I love the ARC software and think it is far superior to the UASD software from Uniden.
I have even promoted ARC software to others, here at RR and elsewhere. I want to purchase the full version, but not until I am satisfied that the software will work properly. As of right now, I do not know that and have no way to re-test the newest version of the software to make sure there are no problems.
