ARC500 Check All CC?
jfhtm350
New Market TN
In ARC500 under Trunck System Objects there is a setting Check All CC: no or yes.
What is that for? I cant find anything in the manual or the internet.
FFEMTCURRENCE
Martinsburg, WV
if look at the Multi-Site column and you choose Stationary...on that setting if you have Check All CC On..then it will check every freq in that system you have programmed in....if you have the Multi-Site either on Roam or Off then the Check All CC wouldnt matter..it only works on the Stationary setting
K3HY
Hermitage, TN
For monitoring a system like York PA from home, is it better to use Multi-Site with stationary?
Instead of control or alternate frequencies, each site can use any of it's frequencies as a control channel.
