k3cfc
Silent Key
I probably would prefer simplex as well but how far is the range HT to HT? When I get general and a HF radio with some wattage well then!!!
Fuzzy the more you get away from 11 meter thinking the better you will be. you will find that bigger better faster and more powerful is not always the answer. repeaters were designed to be used by ht's and mobile's when simplex doesn't work. there are some very good videos on you tube ham nation, amateur logic and if you type buddipole in the search you can see some hams making contacts from their mobiles @ 5 watts. just remember an antenna tuned properly will work the world. a tuner on the other hand only tricks the radio into seeing 50 ohms and does not make the antenna work any better.
K3CFC
