mountedmedic
Hello,
I have a Saber 3 that I have used for the fire service for years. My department is going to switch to narrow band and p25, so I am looking at buying a Astro Saber 3 (share same batteries and accessories) but have some questions. I located a seller with a Astro Saber 3, he says:
VHF 136-174MHz P25 digital ASTRO Saber III. YES, IT IS P25 Digital! Firmware version: R04.01.02 DSP I06.03.00 Flashcode: 540001-000000-4. It is secure-equipped with DVP and DES-XL encryption. If you chose to upgrade the firmware the DES-XL will start showing as DES-XL, DES-OFB because it adds the 2.5 kHz spacing.
He said it is narrow band capable but need to be sent to someone for $100 to make it work. Is this something that can be done thru CPS with the software? (I have the RSS for the Saber 3 and have done my own programming; I know I will need the CPS to do the Astro Saber). Its not clear to me what I would be paying for and I have access to the CPS to program myself. Can someone help me and explain to me what I would need to do to make this Astro Saber work in narrow band and p25? If this isnt ready to go or easily made ready to go, what should I look for in a Astro Saber?
Thanks in advance!
Thanks in advance!
