Astro Saber P25 monitoring
TLF82
Texas
I am wanting/trying to program my AS to monitor Texas DPS' P25 system. So far with everything I have tried I have had no luck getting it to work.
Radio:
Model # H04KDF9PW7AN
Flash Code: 100004-000000-4
I am using CPS 5.03
System I am wanting to listen to: Department of Public Safety (DPS) Scanner Frequencies and Radio Frequency Reference (region 5)
I have gotten it to work with local ham repeaters (non p25), I am just not sure what I am doing with p25.
Thanks in advance for any help you can provide!
FFPM571
Nashvillle
do you have the right NAC programmed? The Astro saber decodes as a P25 capable radio so it should work.
TLF82
Texas
I tried the NAC listed in the database. I also have tried f73. I also have it set to digital CSQ. Do i need to have it on C4FM, wide, or the other one (cant think of it off the top of my head)?
bezking
On the Road
Leave the modulation on the default. Also check the NAC as mentioned above, however if you're really running it in DCSQ then the NAC is irrelevant.
TLF82
Texas
Ok, Thanks. I deleted all of my ham stuff from the radio and it started working.... SO, is it not possible to have both analog and digital in the radio? or is it that i need to have the p25 stuff programmed as the first thing in the radio?
groftcc
The different personalities are independent so you can have a mixture of analog and digital channels. For the digital channels ensure that the RX type is set to ASTRO or Mixed Mode and digital CSQ. This way the NAC setting is irrelevant. Default modulation type should be fine. Make sure that any ASTRO Talkgroups settings are disabled.
In the Zone screen make sure you are assigning the Zone/Channel to the proper personality. It's easy to confuse them if you are not careful. I make it easy and assign personalities 1-16 to Zone 1 channels1-16, personalities 17-32 to Zone 2 channel 1-16 and so on.
Be sure to enable the RX only box to ensure that you are not transmitting on channels you are not authorized on.
Let us know if you need further assistance.
kb0uxv
Minnesota
If your site is simulcast you should set CQPSK, C4FM is for single sites. CQPSK will work on both types.
