Hello everyone;
(I posted this already as a reply to another user's similair problem, but I think that thread had already died out so I am posting here as an original thread now.)
Working on some Astro Spectras here, two of them with encryption installed, and having a problem keyloading the secure ones.
I'll try to walk you through what I've done. I have the 3011DX KVL, KVL Cable, and DES-XL modules, all known good as they were used with Astro Sabers until the other day. I did not have, and could not find, the 7414 Spectra KVL adapter, but Batlabs to the rescue; using the pinouts there I was able to make up an adaptor using a hirose connector and some tiny push terminals I could manually slide onto the keyloader port pins in the Astro Spectra. Believe me, I checked my wiring three times. There's only four wires anyway.
So once everything's connected, the control head will momentarily display "KEYLOAD". But when I press the love button, the KVL just says "fail". I re-verified that the KVL/hi-rose cable/encryption modules all worked in an Astro Saber. But switch everything to the Astro Spectra, and it's no-go. The only wildcard here is my homemade Spectra mic-to-KVL cable adaptor, but like I said I checked the wiring and continuity all the way through, three times.
Oh, and yes, just as you do with the Astro Saber, I went into the CPS and checked secure-equipped and all that. Done it a hundred times on Astro Sabers, and didn't see anything really different in the Astro Spectra CPS. So... I dunno.
Anyone know anything I am missing here? Something about the Astro Spectras that i wouldn't already know from dealing with the Astro Sabers (encryption wise)? Internet search turns up nothing I don't know already, so hoping someone here can turn on a little lightbulb for me.
Regards and thanks!
Brian.
Regards and thanks!
Brian.
