Astro Spectra: VRS & Siren not possible together?
Vintovka
Hello all;
So I've about 99.5% come to the conclusion that there is no way to have both a VRS _and_ siren/PA boxes running together on the Astro Spectras, since there is only the one extra DB25 on the radio drawer (Hi-power remote-mount). (I remember reading the analog Sys9000 boxes could have both the VRS and Siren circuit boards installed in them, but apparently not an option for the Astros).
So is this correct? I only ask in the off chance someone will pipe up with, "Yes, you just need that optional, commonly-available Y-cable...." or something that I've somehow overlooked. =)
Thanks,
Brian.
Motoflightmedic
Ø
It is possible, but it takes a special T cable that has both the connector for your VRS and and the connector for the siren amp. what type of VRS are you wanting to use?
Vintovka
So there IS light at the end of the tunnel. Well that's good news. Thanks for your response...
As for the VRS, the VRS-EP P2017 UHF seems plentiful enough. All I need is to be able to mode steer based on PL tones from the portable radios.
Do you happen to have a part number for this T-cable? I didn't notice anything like that in my service manual, but if you know it's in there I'll go back over it.
Thanks again,
Brian
