Anytone at 778uv radio
Aircargo
North New Jersey
hi...just received this radio. little,nice,tricky. size of a bible. software not as powerfull as on the d878uv,tool option missing which made tricky to move freg from at878 to 778. im using a tram mag mount and put in expedition today. need a cigg adapter not includeded unless u hardwire it. i bought another power wire with same plug for shack which makes easier to plug and unplug when programming. 25watts...heard 21 max.....lets check it out! 73 all....
KE5MC
Lewisville, TX
I got one to backfill the 1st gen FTM-400 I just sold for home use. Loaded up the 3.0 CPS and didn't see any copy/paste/import function. I've already programed about 10 channels which is a little tedious, but better than FPP. I don't Chirp, but usually RTS or factory software. As I'm typing this out I just remembered I have used ContactManager for DMR 'stuff'. I'll have to check if it can read/write '.dat' files.
Seems like you might have a way to get 'stuff' from 878 to 778 computerize. Any information would be helpful.
Mike
P.S. Nice radio for the money. Not top tier with lots of options, just a basic 2 band modest power out radio for a reasonable price.
KE5MC
Lewisville, TX
ContactManger does not read .dat files. I reached out to RTS and got the absolute answer that only their cable work with the software. That is contrary to their website that say some supplied factory cables may work. I'll struggle with the Anytone software and cable. Really once a radio is programed changes are usually incremental and limited. I think the person from tech. support was just giving me the safe answer.
