SDR# Audio piping
PDXh0b0
Woodland, WA
How do you pass your audio from your sdr software to another program?
Example
Sdr# to fldigi
I am using a vb-cable to pipe the audio to fldigi, issue is, when another process starts or increases it's consumption of resources, there is a shifting in the image
(This also can happen in other decoders, like rx-sstv, cause some decoders like scytalec to stop decoding)
Worth mentioning that I running 4 vb-cables
Wxtoimg will get image shifting if I open another program, like a browser, but shift if corrected when decoding
Sdr++ - 3 vfo's - vb-cable B,C,D - wxtoimg
Sdr# - 1 vfo - vb-cable A - fldigi
Microsoft Laptop Go - 4gb ram 😮‍💨
Windows 10
Pc isn't the greatest
sonm10
Central MN Monitor
Sauk Centre, Minnesota
You may have seen the thread I started about distorted audio. There is a setting to change to fix that problem. Cable Event [interrupt] period needs to be set to [1].
