Austin-Lake Travis
bmathis
Texas
I would like to hear all communications on Lake Travis (LCRA,Fire,Game Warden,Travis Co,EMS,...) What scanner and type of program do I need
rattlerbb01
TX/LA Database Admin
Boerne, Texas
If you go with a Uniden scanner, you will need a BCD396T if want handheld, or a BCD996T if you want a base model. The older models that will also work are handheld BC296D and BC796D base. You can download ARC396 and ARC996 from Butel at www.butel.nl for the newer models, or ARC250 for the older models. It is something like $30.
If you go with a Radioshack scanner, the Pro96 handheld and the Pro2096 base are the only ones currently available. They are programmed best with Win96 found at www.starrsoft.com. Same thing goes with $30 to purchase.
You will find LCRA on their EDACS Wide 900 MHZ system here:
http://www.radioreference.com/modules.php?name=RR&sid=48
You will find many fire departments, as well as all Law Enforcement/EMS in Travis County on the Austin/TC system here:
http://www.radioreference.com/modules.php?name=RR&sid=2
And the remaining fire departments not trunked can be found on this page:
http://www.radioreference.com/modules.php?name=RR&ctid=2749
