AVP ATC transmissions
IronEagle20
I recently inherited a bearcat BC345CRS and plan on using it for listening to air chatter. I pick up a considerable amount of chatter on 132.175 with the stock antenna. was wondering if I upgrade the antenna could I pick up the ATC at AVP which is about 13 miles away
Whiskey3JMC
Airwave surfer...Cowabunga!
Philly burbs 🇺🇸
You'll never know unless you try. Not all RFI environments are created equal, YMMV. When conditions are favorable I can pick up ATC at PHL from just shy of 20 miles away on my Icom IC-R20 with stock telescopic pointed towards the air field
RichardKramer
Reading, PA
Most of the VHF ATC freqs are paired with a UHF freq for the military to use: 132.175/298.9. This is New York Center (ZNY) High sector 34 Flight level 240 and above .
Rich
popnokick
Northeast PA
Depends on terrain between you and AVP. If you're on a mountaintop / mountainside overlooking the airport, then probably yes. If you're behind one of the "Endless Mountains" in the area... then likely not. Regardless, a better antenna (meaning outdoor, not a back-of-set telescoping rod) will improve everything you receive.... possibly including AVP tower and even ground. But as has been pointed out, you won't know unless you install the better antenna.
cpg178
I live below the airport about a mile away, I can hear the Approach, Departure and Tower fine, but cant get ground since I am sitting below the airport elevation. I agree with popnokick, your location will be the best determinant as to whether you can get what your looking for or not.
