- Joined
- Nov 11, 2004
- Messages
- 82
I was having a problem hitting some of my local repeaters with my VX-P929. In the software everything was setup correctly with the tones and offsets. The tones were encoded but not decoded. When I went into the FPP mode, the decode was turned off and the encode tone was 67.0 hz. The radio wouldn't let me change it. When I turned on the decode and set it to the correct tone, the encode tone followed and I could bring up the repeater.
I contacted Vertex tech support and they told me that sometimes as you are entering in the channel and radio information into the programming software, the file becomes 'bad' and things like I described happen. They told me to write to the radio often and save the files often as different file names so I can go back if something is corrupted.
I can't be the only one that has had this problem. Does anyone have a 'trick' to make sure their data files aren't 'bad'?
Thanks,
Jerry
Thanks,
Jerry
