W4OP
I have seen this theme before and wanted to post an image of one of our asymmetrical notch filters and a 1/4 lambda open stub comprised of RG-8X.
This filter is designed to recover more quickly on the high frequency side of the notch. The assymetry can be reversed so as to recover more quickly below the notch or the filter response can also be made symmetric. Both the filter and the stub offer about the same attenuation- around -30dB. But as you can see, the notch recovers to -3dB in about 900KHz., or about 0.5% of the notch frequency.
Dale W4OP
Dale W4OP
