Baofeng UV-5R
mjz55
PA and NJ, USA
Not sure if this is the correct spot to post this or not but. Does anyone know if the Baofeng UV-5R is in the FCC 2013 narrowband compliance? I know it's cheap. I was looking into the Wouxun KG-UV6D and it was mentioned that it is in compliance but there is a big difference in price. I appreciate any comments/suggestions.
AE5NW
Yes, the UV-5R is compliant and has the capability for narrowbanding.
However, if you're using the radio for amateur use only, the point is moot as amateur radio operators are not affected by the narrowbanding requirement:
Radio Amateurs Not Affected by Narrowbanding Requirements
I've had mine for about a week now and, so far, it's been a great radio for the price.
73, AE5NW
WA3CSX
Brentwood,Md PG
baofeng radio
while you guys are on the subject of this radio.I would like to know how long did it take you to get your radio? and did/have you order any accessorys seperate for it yet? and if so how long did that take to receive it ?
K9WG
Greenfield, Indiana USA
I got mine from Amazon.com and it took about 6 days. So far pretty impressive for a $60 radio. It does have some interesting firmware bugs though....
AE5NW
Same here.
The first one took about a week. The second one, slightly less.
PT
WA3CSX
Brentwood,Md PG
ok thanks guys for your replies,I was total unaware that Amazon sold these radios.Now after looking on Amazon,one more question,will the battery for the baofeng uv-3r fit the uv 5r ?
AE5NW
Nope. It won't.
Baofeng UV-5R (Import Communications)
Or...
409ShopUV-5R www.409shop.com (seems to be down at the moment though, so check again later.)
You might find those sites useful.
Now, the radio isn't perfect, but for the price point, it's darned hard to beat and enters the realm of "disposable" devices.
I used one for the entire trip to, walking around at, and returning from, Dayton Hamvention this year. Didn't have a single problem one with it.
73, AE5NW
WA3CSX
Brentwood,Md PG
thanks,the 409shop is were I ordered it from and STILL for it,hopefully it is in and my friend brings it to work tomorrow(now later on today).
taboudarajr
Santa Rosa CA
Narrowbanding
I've been working with CHIRP and through the on radio menu and I can't get my radio to stay in "NARR" mode.
I have a multitude of PS channels programmed into my radio, and since they are all narrow banded, I suspect my radio should be as well.
Any thoughts?
jonwienke
More Info Coming Soon!
VA
Look at the MODE column (third from right in channel list). "FM" is normal FM, "NFM" is narrow band FM.
KC9HI
Any thoughts?
In MR/Channel mode, menu 5 is "read only". In other words, it can only be used to see how WN is set, not for changing it.
The only way to change this setting at the radio is to erase the channel and then reprogram it from VFO/Frequency with WN set to the desired value. Most of the per-channel settings are this way.
Reference for UV-5R Menus
The only other way to make the change is by using programming software. With CHIRP, the Mode column sets the bandwidth. FM=WIDE and NFM=NARRow. Once you choose FM or NFM from the drop-down menu in CHIRP, the choice will show in the field, but it isn't selected yet. You must press [Enter] or click onto another field for it to be permanently selected.
A quick way to check to make sure that your selection "stuck" is to press the [Go] button. If you made the selection properly, it will still be selected. It will revert back to the original value if it wasn't. Saving the channels and settings to a file or uploading them to a radio will also cause them to revert back if they weren't fully selected (and the original values are what will be in the file or radio).
Jim KC9HI
