Base Setup
blueknight05
My setup consist of a StarTech 12U Desktop Rack, A Uniden SDS200, Uniden BCT536HP, Realistic PRO-2022, and A Senhaix N60 Network Radio. I have a Uniden BCT15X coming that will be mounted also. The scanner rack panels with speakers are from Alberta Radio Supply. All the Uniden scanners are connected to a secondary computer to keep my main computer free.
03msc
RF is RF
The Natural State
cmjonesinc
Network "radios" are argued about all the time as not being "real radio" as they need the internet or a private network to communicate. They have their place though. If you've got a business with a solid wifi network in place or you need to link 2 locations together they work well. Personally I like the actual radio style setup like the op has instead of just using the phone app. Having a dedicated device with a loud speaker is nice.
N9JIG
Sheriff
Moderator
Far NW Valley
Nice job, I like the mixture of old and new along with the rack job. ARS has some neat stuff. I like that cable pass-thru panel, I hadn't thought of that before!
blueknight05
durango5550
Booger D.
uh oh , you gave Rich another idea .......
Nice setup!
dispatchgeek
Control channel goes "brrrrr"
Between the cornfields and the pastures, Michigan.
I’ve found them on various resellers as a “1U Brush Grommet” Not that I’ve been uh, looking for one.
blueknight05
What are you using for a monitor mount for the upper monitors?
The 43" bottom monitor is using it's factory mount (it was to heavy for the mount I had), the upper monitors are on (2) separate Wali 31.5" pole mounts. The middle upper is a fixed mount and the right upper is on a movable arm mount. The security camera monitor and clock on the left are mounted on a 48" Wali pole mount.
blueknight05
Upgraded the radio rack with twin 7" monitors running flightradar24 and marinetraffic
JimD56
KO9JAD/Retired-Fire Lieutenant/Paramedic
Davie, FL (Miami/Fort Lauderdale Metro)
@blueknight05 great set up, I have the same rack with few scanners. would you please provide more photos of the inside and the face panels source?
Faceplates are from Alberta Radio Supply off of Ebay. Tons of us on here have used them. Colin is a great guy with speedy service.
