Battery question from users of G4 G5?
mitbr
Tampa Bay Florida
So.... I went to use my g4 today after it was out of the charger for around 5 days and it was dead. How many days are others getting. Seems to me it drains the battery pretty quickly when off the charger when not turned on. The g4 was fully charged and the battery is only around 3 months old.
Tim :cool:
wmlovell
Aurora, OH
Make sure you have the latest firmware that fixed an issue where the radio was on even though you turned it off. You would get no sound or display but after some time, all of the LEDs would turn on continuous red. Once I updated, my battery lasted again.
kruser
Well Known Member
W St Louis Cnty, MO
Tim :cool:
I just found the same exact dead battery situation in my G5.
It had been in the charger for a week or two unused so it should have had a full charge.
I took it out of the charger base about 7 days ago and set it on the desk, Just now tried to turn it on after reading your post.
The G5 will not power on nor will it show that it's charging on the LCD when I put it in the charging base or plug it into USB power.
The RED LED does light on top of the G5 indicating it probably is charging.
I took the battery out this time and it measured 2.66 VDC so not totally flat.
This is the newer Lithium Ion cell that Unication sent for free to replace the original Lithium Polymer cells.
I've had this same exact problem with this G5 before and I think the old Li-Polymer cell. When it happened then, I failed to measure the cell voltage to see if it still had some voltage in it or not. Most people know that running a Li cell totally flat usually ruins the cell permanently.
In that earlier case, I could not even get the G5's charge LED to come on when hooked to a charger. That kinda told me the cell was probably flat as in 0.00 VDC.
In order to get that one to charge, I had to attach an external trickle charge voltage of about 2 volts to the cell and then it started charging in the G5 again.
Right now I just looked at my G5 again sitting in the charging cradle and I could see right away that the charge LED was much brighter and it does power up now with a low battery warning.
I turned it right back off though but I'm sure it will go through a cold boot when I do turn it on after the charge LED turns green.
After this happened the first time, I've usually just left it sitting in the charging base or hooked to USB power as that should not hurt anything if the charge circuit is turning off like it normally does with Lithium cells.
I also have an Icom IC-R30. I place it in its charging cradle and it will charge until full and the LED turns green. But... if I don't remove and place the R30 back into its cradle every so often, the charger will never turn on when the cell starts getting low when not even using the radio.
I tested that with USB charging and the R30 did the same thing. It will always charge to 100% but if left in a charger or attached to an always on USB power source, it's not smart enough to keep itself topped off at 100%. I must remove charge power and reapply it again in order for the R30 to charge back to 100%. I can also trigger the charge to start again by simply turning the R30 on for a minute and then back off and it will charge back to 100%.
Now I'm wondering if the charging circuit in the G4 or G5 does not have the same limitation as my Icom IC-R30 where it will always read full even when it has self discharged while sitting in the charger cradle. So when you pull it out, it may not have really had a 100% charge if it has not been used but attached to a charge power source for several days.
I need to test that with the amplified charging base I usually use as well as when charging with a USB power supply and cord of 1 amp or more capacity.
mitbr
Tampa Bay Florida
The pager works well when on for around 8 hours so it seems to be charging ok.
mitbr
Tampa Bay Florida
i don't have the latest firmware i think its 1.30.yes it is 1.30
kruser
Well Known Member
W St Louis Cnty, MO
Yes it was full.
Exact same that my G5 showed both times this has happened now.
After mine did this the first time, I tried to duplicate the issue by charging it to 100% again and then purposely let it sit on my desk out of the charger and turned off for two weeks and it still powered up and showed a full battery.
MidwestRadioListener
Altoona Iowa
I did the battery turn in a couple years ago or whenever that was. My battery was only about a year old, I always felt like I should have not done that. The battery that I sent in to trade performed way better. I have just dealt with it for now but I think it's about time to buy a new one and hope it's better as I've gotten my moneys worth.
I love my G4 though, it's got a great receiver and works great. If I could change one thing it would be a better louder speaker to compete with APX radios, for being a public safety device I feel like it's awfully quiet for my older ears ;)
krokus
Southeastern Michigan
The old batteries were a problem. I'm not sure how many I replaced for my department, but they all swelled. The pager would get warm, after that happened.
kruser
Well Known Member
W St Louis Cnty, MO
My G5 battery did charge back up just fine and seems to have its full normal capacity after I did an 8 hour off charger test with it receiving a medium use system.
