ErikSwan
I recently purchased a BC125AT as my first scanner, mostly to use for airband and general analog scanning before possibly exploring a more expensive and capable scanner like the SDS100, but I'm a little dissappointed with the number of birdies that I'm picking up with the BC125AT.
To get away from the local RF noise in my electronics-filled home, I took it to a local park and just started a basic "custom search" just to see what I could find prior to programming the scanner. I noticed that the scanner would lock and break squelch on quite a number of frequencies that didn't seem to have anything on them - I would just hear white noise, complete silence, or occasionally, more of an impulse-type static sounding noise.
When I got home, I ran a basic test: I reset the scanner to factory defaults, removed the antenna, and started a "quick search" at 25 MHz and let it search through the entire frequency range supported by the scanner.
I was surprised to find that at the default squelch setting (2) it was still stopping and breaking a squelch on a large number of frequencies and picking up what must be spurious signals/birdies from inside the scanner.
Here is the complete list of frequencies I had to lockout before it would complete a full search through the entire frequency range without stopping on a spurious signal:
Again, to re-iterate, this is with the antenna completely removed, so these are not "real" signals.
Is this normal? At the default squelch level (2), that's 72 of the 100 available permanent lockout slots used just to lockout the internal birdies of the receiver!
The scanner does appear to otherwise work normally - I've been able to pick up airband signals quite well and occasionally close call will get triggered by what appears to be a very high-powered POCSAG pager transmitter nearby.
Are my expectations too high for a $100 consumer scanner, or is something wrong with my individual unit?
Code:
28.5500
30.8000
30.9900
32.0000
34.0500
38.9750
39.3300
47.6700
49.4000
125.1000
135.0500
144.3500
145.9500
155.9025
165.2000
229.3500
239.3000
250.2000
256.5375
260.1500
271.0500
277.3875
281.0000
282.6000
287.8125
291.9000
293.0250
298.2375
303.4500
308.6625
312.7500
313.8750
319.0875
323.7500
350.9000
354.4500
361.3250
363.7875
365.4500
369.0000
371.7500
374.2125
375.3000
379.4250
400.2750
405.4875
406.5750
407.1500
410.7000
411.7875
415.9125
417.0000
421.1250
426.3375
428.0000
431.5500
436.7625
437.8500
441.9750
448.8500
452.4000
458.7000
462.2250
462.8250
469.7000
473.2500
476.3125
479.5500
483.6750
490.5500
500.4000
511.4000
