bc296d vs. bc396t
moonies
seaford long island
After having a bc396t for about 5 weeks now, after updating the firmware to the current version, and after listening to apco transmissions side by side to my 296d, I have to say the ONLY difference in the PLUS column is the memory allocation!! The digital voice is sub-par on the 396t. The 296d,after the firmware update BLOWS AWAY the 396t in my opinion. Even on distant apco frequencies, the 296d is much more stable on the decoding of signals,UNLESS the agency is in your back door, the 396t fails miserably on the stability of the signal!!! Maybe I have a bum unit but I am disappointed with its performance other than its capability to hold ALOT of systems.
moonies
seaford long island
Yes, I agree. Thats why I can say it doesnt compare because I am using the austin condor antenna as well as the spectra mobile antenna,2 very high quality antennas.
iMONITOR
Silent Key
S.E. Michigan
The factory tries to have a one-does-all antenna, which doesn't do anything good. When I had my BCD396T I used the BNC adapter with the RS800 from Radio Shack, and there was a marked improvement. The RS800 performed very well for the 450MHz band as well.
wjf
Witness Protection Program
I second that.
Raven95150
Nowthen, MN
I have a 396, a friend of mine has a 296 and since he is a captain on the FD, he has his own portable radio. My 396 blows the 296 away for clarity and reception, in fact, it is almost as clear as his FD radio. The 296 breaks up and had garbled audio quite a bit, while the 396 is nearly crystal clear most of the time. The only complaint I have about the 396 audio is the volume, it could be a little louder. It is a little hard to hear if you are in a noisy environment.
EDIT: I should note that both my 396 and his 296 have the RS 800 antenna.
ButchGone
Ringgold, Georgia
Re:
I have a 296d and also believe it's better at doing digital than the 396. Keep in mind, you must get the digital settings (manual adjustment) correct to work/sound properly. I have compared the 296 to several 396's, most recently two 396's in the same car as mine while listening to a 3600 baud system. I found the audio quality similar, but the 296 has more bass. However, the 296 seems to decode and pick up talkgroups faster than the 396. Again, with two 396's in the car with a 296, the 296 will get transmissions about 1-2 seconds quicker. I don't know why, but it's a consistant delay on other 396's I have tried. I understand the 396 has several parameters that can be manually adjusted for digital reception, so maybe they can work as well if properly set. I have also found the 296 quicker with conventional systems. On a VHF-hi band digital ASTRO system, the 296 will get all the transmission where the 396 doesn't begin decoding until after a word or two.
I agree with the first posting...the 296 performance wise is as good or better, but the 396 wins as far as wiz-bang features and more memory. I do find the 296 much simpler to operate on trunked systems...I can manually step to whatever talkgroup I want instantly and don't have to scroll through all the groups. I can also set some talkgroups as "priority," so as to not miss important groups/events. The 396 does have have ability to set up priority talkgroups...a feature I use a lot.
BG..
Soundman
N.C
I have a ?
What do you mean by firmware? I am looking into getting the 296d .Charlotte will be moving to the new 9600 by next year sometime and I would like to have a scanner that will be ready when thy do.I have a 250d that was digital ready but I found out thy are going to the 9600 so I am screwed .So I am going to have to get the 296d .I love that model because of the speaker being on top .I only trust Bearcat .Do you all think that is the best model to go with.
moonies
seaford long island
ownng the 296d
Yes, I do suggest picking up one if you can find one. Since the 396/996 units they stopped producing 296ds. I deal with lentini comms in connecticut so give them a shot or uniden directly.
DaveIN
Founders Curmudgen
West Michigan
Keep in mind the 296 will not track 9600 baud I-calls on a P25 system, only the 396/996 will do that (also 700MHz trunked, just in case you would need it sometime in the future).
Soundman
N.C
What ?
I heared that the 296d will pick up the 9600 band just fine .What do you mean by that .I would like to know before I buy this unit ?
