BC396XT Issue
Metrofire31
Auburn-Opelika, AL
I've had my BC396XT since they first came out but this morning, began experiencing an issue I've never encountered before. In my car, I have a 396XT in my glove box connected to an RH-96 remote on the console. Each time I power up the car (and the scanner/remote), it powers up on "HOLD" and on a talkgroup that I was not monitoring when I last turned it off. When I last turned off the scanner, it was in "SCAN" mode so I can't figure out why the scanner/remote is powering up in "HOLD" mode.
Any ideas?
Ronaldski
MI DB Admin
Bay City MI
In glove compartment? Something in there fall on the 396xt to push a button?
Metrofire31
Auburn-Opelika, AL
396XT Issue
No, I checked on that. Besides, it's unlikely that it would cause it to be on hold only when I power it up AND allow it to scan normally when it press "SCAN".
garys
Central Texas
That is odd as the DMA scanners are supposed to power up in the same operating state that they were turned off in. Have you tried powering it up without it being connected to the control head? Also, how do you turn it off and on? That is, have you removed the batteries and are powering the scanner externally with a switch? Or do you have the batteries in and have to use the power button on the scanner?
W6KRU
Vista, CA
I could be wrong so don't hold me to this but i remember something about the "last mode" not being preserved if power is removed from the 396XT. The power switch has to used for that function to work.
KE4ZNR
Radio Geek
Is the word "Hold" flashing?
If so long press the Hold key to turn off system Hold.
Marshall KE4ZNR
Metrofire31
Auburn-Opelika, AL
396XT Issue
Marshall gets the (imaginary) prize - it evidently was a system HOLD because his suggestion worked. Not sure how I put it in system HOLD - Marshall, got a clue about that so I don't repeat it?
Thanks to everyone who wrote in
UPMan
In Memoriam
Arlington, TX
Pressing and holding HOLD holds on the current system. Doing it again releases the hold.
