BC796 Programming help
cg
Connecticut
There are several programs that can be used to program that scanner. ProScan and whatever ARC program Butel sells.
You still need to put the information into the programs but there are aids built into ProScan for importing from RadioReference.
ProScan
It has been so long since I used the ARC250? program, I can't recall if they do importing from a website.
Software for Uniden Whistler HOME PATROL HP1 HP-1 PRO-700 BCD436HP BCD536HP Radioshack GRE GRECOM MFJ DSE AOR police scanner software BCD996XT BCD396XT BC346T BCT15X PRO-404 PRO-405 PRO-97 PRO-96 PRO-2096 PRO-106 PRO-197 PRO-164 PRO-160 PRO-162 psr50
chris
JamesO
McLean, VA
You can also hand program the 796D without too much problem.
I also recall the scanner may need the firmware updated to deal with rebanding, so depending on what you are monitoring, you might want to check the firmware version and look into the Re-banding issue.
