Upon receiving my BCD396T, I programmed it using RadioReference and the ARC 396 Basic software. All of the systems worked fine, including the City of Allentown PA’s EDACS system. I actually deleted the Allentown EDACS system and re-entered it without any problem at least twice. Last Sunday I added a number of talk groups to the Allentown system using ARC software. As soon as I did so, the scanner stopped receiving the Allentown EDACS system in trunking mode. If you manually step through the channels, the scanner is receiving signals conventionally. So far I’ve done the following without success in resolving the problem:
• Deleted the system from the ARC profile, recreated it and uploaded back to the scanner.
• Initialized the scanner’s memory and then uploaded a new version of the Allentown EDACS sight.
• Verified that the correct frequencies are loaded in the scanner and that the LCN assignments are correct.
• Display shows NFM.
• The system is not locked-out.
• I increased the channel delay time to 4 seconds.
• Changing from ID scan to ID search had no effect.
• I-Call is set to “on”
• EDACS ID format is set to Decimal whish is the format for the talk groups I imported.
• None of the frequencies are lock-out.
• None of the call groups are locked out.
• Proper quick key is selected.
I’m baffled and would appreciate any suggestions. Note that the radio is receiving a Motorola trunking system in the adjacent town with no problems, so I don’t think the radio is the problem. I think it's the user!
Many thanks!
Many thanks!
