bcd396t programing question
jakegday
Banned
#1
hello, when i use arc396pro to add/subtract systems to my scanner, when im done, every system is "reactivated", by that i mean they ALL start scanning, so i have to go through my approximately 30 quick keys and disable about 28 of them so im left with my 2 original systems scanning, is there anyway to stop this from happening?
Memphis, TN
#2
When sending data to the scanner, there is a check box to send system quick key status to scanner. Make sure that is unchecked, and whatever system quick keys were enabled / disabled prior to writing to the scanner are untouched. Note, I have version 2 of Arc396.
Hope that helps,
David
