I was bored and decided to do some testing of my 396 after all the recent discussion of the lack of sensitivity of this unit in various threads.
This is in no way professional or even an ideal test setup. It's just me in the garage keeping myself busy but here it goes.
Test set: IFR1900CSA 100khz-2.1Ghz capability
Radio: BCD396T
serial# 328Z5400077XX (XX left out)
On battery only at 3.77 volts
Measurements taken from monitor in micro volt setting not dBm
First number is Mhz, Second is voltage to open squelch, Third is voltage to close squelch. Voltage levels are micro volts
130Mhz .273, .207
140Mhz .240, .203
150Mhz .260, .216
160Mhz .275, .216
170Mhz .275, .241
418Mhz .525, .300
440Mhz .525, .320
460Mhz .550, .340
866Mhz .476, .300
1293Mhz .475, .280
S Meter votage at each step at 155 Mhz:
micro volts
S1= 1.2
S2= 2.16
S3= 3.99
S4= 6.020
Radio: BCD396T
130Mhz .273, .207
140Mhz .240, .203
150Mhz .260, .216
160Mhz .275, .216
170Mhz .275, .241
418Mhz .525, .300
440Mhz .525, .320
460Mhz .550, .340
866Mhz .476, .300
1293Mhz .475, .280
micro volts
S1= 1.2
S2= 2.16
S3= 3.99
S4= 6.020
