Hi all,
I recently acquired a BCD396XT so I can have a portable scanner...I already have a BCD996XT and wanted something portable that could use the same programming as my 996. It has been working flawlessly for about a month, and suddenly today it will not power on while on batteries, I have the Eneloop 1.2v 1900 mAh Ni-Mh batteries, they are fully charged. When plugged in the 396 shows normal charging. When powered on while plugged in the voltage shows around 4.0. I have checked the switch inside, and it is set to Ni-Mh. I tried it with a set of alkaline AAs, changed the switch over to alkaline, and still nothing. The unit has not been dropped or otherwise abused. I did use it for about six hours this past weekend when we had a power outage, and everything worked fine...voltage dropped to about 3.75 volts, but charged right back up, and ran on batteries after charging. I did try a fresh fully charged set of Ni-Mh batteries with no change....it will not power up on batteries. I do not have an external charger, and I generally do not charge the batteries any longer than about 2 hours in the radio since I don't use it much on batteries. I have not yet tried factory resetting it...I wanted to check here first and see if anyone had any ideas before I wipe it out and re-program.
Thanks all!
Thanks all!
