bcd396xt
lowney4
I cant get my scanner to stop scanning the service search.I have tried everything.I just want to shut it off,so I can listen to my regular system.
MarMatthias
Nebraska
Hi,
The easiest way I've found is to go to :
1. the MENU
2. SEARCH FOR
3. EDIT SERVICE
4. pick a service
5. SEARCH WITH SCAN
6. SET LOCKOUT
7. LOCKOUT
Repeat that for every search and custom, then you'll get what you want. You'll have to manually select the services and customs from then on out. Works well for me.
lowney4
Thank you very much.Ive decided not to kill myself.I tried to figure it out for three days.
lowney4
can you tell me how to lockout certain ID'S from normal scanning?I listen to police in persuit,then bob is fixing the toilet at the high school.I would like to remove these ID's.
UPMan
In Memoriam
Arlington, TX
Even easier: When the scanner is in a service (or custom) search you don't want to actually search, press F+L/O, L/O to permanently lock it out.
werinshades
Chicago , IL
Friend of mine did exactly this, and while locking out each individual Service Search is a workaround, my suggestion is to do what we did. I use ARC software and deleted all systems and reprogrammed the whole scanner. He was a proverbial "button pusher", and added a service search somehow and had no idea what he did. I have both XT models, and never saw that before, so I wiped out the whole thing and problem was resolved.
lowney4
Thanks again for the information.Now I would like to know if you know how to remove ID's from the system I have going.I like to listen to the police calls,but i dont want to listen to the bus schedule,and problems at the high school.Or the guys removing snow from our streets.I want to lockout these ID's from what i want to listen to.Please help.
ofd8001
Louisville, KY
If you are in the "normal" scanning mode, simply hit the L/O button to lock out something that is being scanned.
If you hit it once, it temporarily locks out the talkgroup ID number (or conventional frequency). When you power the scanner down and then turn it back on, that temporarily locked out ID (or freq) is restored.
If you hit the L/O button twice in rapid succession, then it permanently locks the TGID (or freq) out, even if you turn the scanner off and then back on. Should you want to restore that permanently locked out frequency, then you have to hold on the system and rotate the scroll knob. Once the permanently locked out "thing" appears, hit the L/O button to restore it.
MarMatthias
Nebraska
I tried that, for me it took too long. I knew what I wanted to going through the menu was faster...
MarMatthias
Nebraska
The way that works well for me is to create a group on unwanted ID's, then lock out the entire group. That way you can add ID's to the group and not have to explicitly lock out each ID. I use this method a lot for encrypted TGIDs as I prefer ID search over ID scan.
lowney4
Thank you.
