BCD436HP Priority
lcom
Columbia, SC
I have priority set on my local FD dispatch on my BCD436HP, but it doesn’t seem to be working. Am I missing another step? Thanks
hiegtx
Dallas, TX
Is this for a Conventional channel, or a talkgroup on a trunked system?
If for a Conventional channel, make sure the channel is tagged as Priority and that the scanner has the Priority mode enabled. You should see PRI down in the corner of the display.
If this is for a trunked system, you must enable Priority ID Scan (under the Options tab for the system) as well as tag the desired talkgroup as Priority.
626hawkeye
Edwards, MO
There are two priority modes. Pri DND which olny hits the selected channel is the squelch isnt open. Then normal Priority which will check at selected intervals. It will show up "Priority Mode DND" or "Priority Mode On" when turning it on.
ofd8001
Louisville, KY
Absolutely correct for conventional channels.
