Isinglass311
- Joined
- Jan 12, 2020
- Messages
- 12
Hi all, happy Independence Day eve. I’m spending the weekend in Franklin Cty and I have both my SDS100 and 536HP programmed with the P25 and Conventional ME State Comm Net. With the 536HP and SDS I received the conventional system just fine. With the P25 the SDS works great. The 536HP is completely deaf on the P25 system. I used Sentinel to program both, just switching the target model between uploads. I do have location control active on both and the range set the same at 10. Miles. The 536 will scan the system the same as the SDS but when the SDS locks onto a transmission the 536 goes right by it. Once in a while it will stop on the same frequency but no audio is heard.
The 536 is mounted in my truck with an external antenna while the SDS is handheld with a SRH-77CA diamond antenna. When monitoring just the conventional MSCN both units perform identical. Any ideas what may be going on? The only thing that comes to my mind is simulcast issues.
