BCD536HP WiFi Problem
fire1429
texas
Is there an update for the wifi function I have been trying to connect to my wifi at home and when I put in the password for the wifi to connect it don't connect ???
1. Download Wi-Fi-Updater.zip.
2. Unzip the files downloaded in Step 1. Then, unzip the files in STM_VCP.zip.
3. Navigate to the STM_VCP directory and run either VCP_V1.3.1_Setup.exe or VCP_V1.3.1_Setup_x64.exe depending on whether you are running a 32-bit or 64-bit OS.
Where do I Download wifi updater.zip??
Bote
know-it-all
Ft. Lauderdale, FL, U.S.A.
Run as administrator
When installing drivers and running these updates, be sure to
Run as...Administrator
so that it has access to your WiFi dongle and all the necessary hardware.
This question comes up repeatedly so it should be documented in a wiki at least.
fire1429
texas
I did every thing it said but when I go to write the update to wifi it gives me an error msg!!!! I gave up for today
fire1429
texas
First part of the error
Ncfirewire
i had the same error
before you do the final step
right click on the firmware updater program
click properties
click the compatibility tab
check the box that says run the program in compatibility mode for then i picked windows xp service pack 3
check the box that says run this program as admin.
hit apply
then do last step
fire1429
texas
metzeric you are the man it is updating at this time thank you so much I was going crazy trying to figure this out earlier....
DaveIN
Founders Curmudgen
West Michigan
click properties
hit apply
then do last step
This procedure works. :cool:
Jake68111
Morris, IL. (Grundy County)
click properties
hit apply
then do last step
This thread needs to be locked or put into a WIKI.
Got the same exact error, did these steps and it took.
THANK YOU!
Bote
know-it-all
need wiki
All these good tips must be put into the wiki.
It sure beats 1,798,253 forum posts on the same topic over and over and over and over...
PCTEK
Northern California, USA
WiFi Update Problem
When I try to launch the updater, I get a message that states "PC Cannot Detected Com Port". I am connected via the USB cable and I do get a connection when I run the Sentinel program? I am running Windows 7 32-bit. Thank you
wise871
N.W. Florida
Did you install the drivers for the wifi dongle so Windows will recognize it and give it a com port? Then check device manager and see if it's there with a com port assigned.
PCTEK
It's been one of those days
and it's only Wednesday! I had the WiFi dongle attached to the back of the scanner. I though it would update through the scanner. So I re-read UpMan's instructions again and it said to plug the dongle into my PC... duh.... once I did that it updated find. Now I just have to find how to get the Siren app for my iPad and iPhone....
Thank you
