williamleeporter
Having an issue when hooking up a cable to my scanner. I am streaming to Broadcastify and don't seem to have the right cable maybe. I have tried a Mono cable and a stereo cable and neither one work correctly. When I put it in the REC jack, I never get it to work. When I put the mono cable in the Ext. Speaker jack it doesn't work. But, when I put the stereo cable a little over halfway into the Ext Speaker jack, it broadcasts and records just fine, BUT it also plays from the internal speaker. That's why I thought it needed a mono cable.
I just need clarification on the cable I need that I can use on the REC jack. The settings are right on the scanner and on ProScan because I can record and stream. I just don't seem to have the correct cable, or I have something wrong with my output jacks.
Any ideas?
Any ideas?
