BCD996XT scanner QUIET ?????
llwade
Chillicothe Illinois
Uniden BCD996XT ..... using ARCXT software.....can settings for: SYSTEM, SITES, & GROUP all be left at "DEFAULT" .......... I ask, because the scanner is quiet. I accidently deleted file on the scanner and cannot find a copy of the file on the computer.
thank you for your help
mibzzer15
Fremont, CA
Here is a link to the Easier to Read Manual for the Uniden BCD996XT. This exact link should bring u to the section on resetting the scanner.
Easier to Read BCD996XT Digital Scanner Manual
Here is what the link says.
Scanner Reset - to initialize the scanner's memory, turn off the scanner. Then press 2, 9, and Hold while turning it on (remember the game called Twister?). The scanner will give you the option 'Restore Preprogram List? "Yes"=E/No="."', if you press 'E/Yes', the scanner reloads the preprogrammed systems.
Important! This deletes all programmed data."
Hopefully that helps.
N8IAA
Fortunately, GA
And the software didn't ask you to save the file??? Maybe click on open to see what was saved?
Larry
