No audio / except headphone
I have had two repaired / both return work orders indicated that the J502 was replaced. No other information.
I have had the scanners apart several times to try and find the component J502 and have not. I cannot remember now, but I think a number of the diodes were marked J so I believe it was a diode.
The mistake that caused the problem appears to be due to over voltage applied to the case.
I am working from memory so I will stand corrected but I think if you read around you will find a warning in the manual to NOT use a Grounded Speaker with an external antenna. I guess because of static build up. It woud make its way to ground and damage the audio along the way.
My mistake on one of the scanners I broke was plain stupid. I had the audio out jack in the rear connected to my computer. So the case of my scannner was grounded to the computer case which is grounded. Regarding my power supply, I do not use the wall wart but have a 20 amp 12 v power supply that I use to power many radios. I have a standard power cable with the 2.1 mm center positive plug. As I was removing the the plug and fumbled the cable when the inside (positive) part of the jack hit one of the screw heads on the back of the scanner case. Normally this would not have resulted in anything if the scanner had been sitting independent of any ground. But since the scanner was connected to my computer, the positive inside of the 2.1mm jack found a ground path thru the scanner when the inside of the jack hit the screw head.
How or why that gets into the audio I do not know without the schematic, but the resulting damage makes sense in light of the warning from uniden about not using an exterior grounded antenna with a grounded speaker.
In any case I suspect the J502 might be a SMD and difficult to replace with out some special tools....but if you don't have a job, I guess you might have time to look for it on the board. I looked around the audio amp chip and found some component numbers that made me think it might be close...but I never found it.
By the way, If you have amplified speakers or can pick up some for free or cheap, they make the headphone audio loud enough to be more than adequate.
If you find something, please let us know........Greg
