juskorfus
I have programmed my BCT15X for The City of Pensacola, FL - BUT - I can not get the Fleet Map right for some reason? When selecting either a preset Fleet Map or a Custom map, the BCT15X will not accept the standard DEC OR HEX ID's??? It shows something like 000-12 or other IDs? And if I try to enter the ID's used such as 80 or 00080, it says "Invalid" talk group. When set for ID search it shows something like the 000-12 etc... but I do not know how to identify which talk group this is as it is not listed in RR anywhere? I have ALWAYS just entered the "regular" TG ID's such as 80 or 112 etc, on all my other scanners like the PRO-97 or PRO-164 etc... I am stumped here.
Any help on "converting" the the fleet map 1 ID's such as the 000-12 to something like 00080 or a "HEX" like 005 etc would be greatly appreciated.
you can reach me @ kg4bvd at bellsouth dot net as I do not check the forums but once every couple weeks.
Thanks in advance for any/all help. I guess I am going to have to learn how trunking works from the "ground up" all over again since I have gone to DMA type scanners over legacy scanners.
Walter - kg4bvd
Walter - kg4bvd
