Bct15x help!!
WillB
Henry County
Ok I did something and I'm not sure what I did. I tried uploading new channels to my scanner with FreeScan. Last time I uploaded stuff it didn't work the way I wanted to so I downloaded the programming and started over.
This time when I went to upload I clicked the Erase all systems and settings thinking that would erase all the channels I added. I then uploaded my programming and now it says Nothing to Scan. What did I do wrong? All I want to do is upload my programming so I can listen.
MVUSA
Northern California
Yes definitely check that the quick keys were assigned. I screwed that up when I first reprogrammed my BCT15X.
FreeSCAN, go to "Tools" then choose "System Quick Key Manager" then you can select "Auto Assign" to have the program quickly assign the quick keys for you. That is of course if you assigned the quick keys when you set up your various systems.
