BCT15X scanner
RRUNYON657
Does anyone have one of these scanners? i have one and i dont think i am using it to its fullest....What all can this thing do and what is the easiest way to program it? i have the cable but i have to use a usb adapter to program it with free scan because the other software dont like the adapter can some one shine some light on this thing
thanks
Rob
CoolCat
thanks
Rob
Why do you think you are not "using it to it's fullest"?
Freescan is a great program and should be all you need to program everything into that scanner.
If this is your first DMA scanner, then you will may want to experiment a bit while getting used to the memory setup. 'Design' your systems and groups with quick keys in mind (and remember, you can assign more than 1 system to a single quick key).
