BCT8 vs, BCT15X
ptr1959w
Vero Beach, Florida
Hi there,
I was wondering what you guys think of these 2 scanners ?...Both the pro and cons...I am a newbie to scanners..:)..also looking for a great buy.any help is greatly appreaciated..Thanks,
Ptr1959w.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
ptr, the BCT8 is very old technology; the 15X has many more features, and I believe it to be a superior scanner for many reasons.
But we're really getting ahead of ourselves. You need to answer a few questions in order to choose the scanner that will work the best for you;
- What do I want to hear?
- If you're a ham, you have the option in Florida, I believe, to have a scanner in the car. Are you going to listen primarily when you are at home, in the car, walking about...
There are many more questions and issues that you need to consider, and we have a couple of things in our wiki that can help. Go to the blue toolbar under the Scanner Master ad, float your mouse over Wiki then select Wiki Home. The resulting page has a section called 'Links for Newcomers'. This is where I would start, particularly emphasizing the Scanner 101 and Scanner Q&A articles (in all cases, both in the wiki and here, anything in blue is a link).
You can easily research any of the popular scanners by using our wiki - keep the Glossary link handy, as I'm sure you will refer to it a lot as you go. In that same pulldown, there's a selection called Radio Models In the preamble of that article, you have 2 links - click on Analog Trunktrackers From there you will get a list of all the analog trunktrackers on the market. Click on the one you wish to research.
73 (best regards) Mike
ab8sn
Camden On Gauley WV
BCT8 vs BCT15
Hi there,
Ptr1959w.
ptr
I have two 8's and the 15 model (not the X version) and they both are fine scanners. The 15 has over 10 times the memory, alphanumerics, and ctcss/dcs squelch which the 8 does not. To me the 15 is more sensitive as well.
I like my 8's due to the fact they are a lot easier to program "on the fly." In my state over 70% of the transmissions are still conventional analog so they are still getting a lot of use here. Also the 8 model does not have special features to control the type and volume level of the beartracker alert tones whereas the 15 does.
I highly recommend downloading programming software if you decide to go with the 15X model since it does not utilize the banks and channels way of programming unlike the 8.
Hope this helps some
73s
Chad
