jimvm
I checked this afternoon and the P25 trunking system is off the air.
Still off at 7 PM. Nothing on 380-400 MHz either.
Maintenance?
jim vm
Maintenance?
jim vm
Maintenance?
jim vm
Great find! It's interesting to see they elected to put the new P25 system on VHF 136-143 MHz and not 380-406 MHz.
I don't have a BCD996, but isn't there a P25 auto detect mode? It should be as easy as setting "P25-Auto" (or maybe P25-VHF) and inputting the control channel, because P25 announces the bandplan thru the CC.
Can anyone run Pro96Com or Unitrunker on the new system and let us know what you find?
Yeah, this is the older 3600 style of system. Nice assumption-derailment Inigo.
All they did is swap the UHF stations with VHF ones. Kept the same controller and had Moto issue them an upgrade for VHF use. It's not really that special of a move.
For those of you with an XT or 500/600/800 you need to get a raw output of the control channel. And then one of us can calc it for the base and spacing. You can always try 138.0000 or 138.0125 with 380 and 12.5 to get started.
Based on what I was told by a former "user" the coverage was never that great on UHF.
For that style (along with the 800) you would think they would add the math to do it. It's nothing complex. In many cases you don't even need any voice channels but it helps to confirm the spacing.Wonder if the HP-1 can help map out the system? Gotta go find it...
