mastr
- Joined
- May 7, 2005
- Messages
- 527
- Reaction score
- 387
...Now if I only had my old Regencys. Touch m100 series?...
I probably have one around here someplace if you actually want one.
A lot of the NYPD mobile units in the 70s had black telephone style head sets.
I remember some of the MBTA buses here in the Boston area had them too.
Saw this display at the Old Lyme (Connecticut) Fire Department today as they celebrate their 100th Anniversary. When I started as a volunteer firefighter in early 1970’s, I had been issue a Plectron and at one point a Viking, similar to the photo, but it was red. And of course I had a Bearcat III. Departments in southeastern CT in those days operated on 33.90, 33.92, 33.94 and 33.96. Simple.
Probably Robyn scanners. There were several models. You could change the lenses to several colors to your liking.I can't remember the brand of scanner I had in the early 70s but it had 10 (I think) lights across the front that I could stick color chips in. There was a CB/HAM/scanner store near me that stocked most of the crystals I needed (Chicago PD). I used to play it through my stereo!
Does it still work?My bc101 is sitting in my basement..maybe I will see if it still works…it did about 2 years ago
Bearcat IV still in pristine condition, sitting in m
This uses pin prong wires to change the L/H/U and the Bearcat BC-4 uses slide switches and a metal case, better sensitivity too.this maybe.....
Haven’t got around to trying but will…I have to find the manual since it’s certainly not obvious how to enter a frequency!
The BCH was their first scanner, in 1968. The BCII had channel lockout switches that the BCH lacked. (see post #8) Was the BC-U2 just the UHF version of the BCH ? Was there a BCL for VHF low?The 101 was probably 1976 or so.
The BC-U2 predated the BCII and might have been as early as the late 1960s.
The Electra BCH was the earliest scanner I think they made.
The list here on the Wiki has some more detail, but there is still a lot of missing information.
This list is better for Electra, but doesn't include the BC 250, BC300, or BC350. The 350 had an Alphanumeric display. Neither the 300 nor the 350 had good receivers as a I recall.
I think the Bearcat 210 came out in early '77. I have an early version (March '77 date code) which has the backup battery mounted directly to the PCB vs the usual external holder on the rear panel. Replacing the battery requires opening the radio up.
Sounds right for the 250. I think the earliest date code I've seen for the 250 was 1978, but could be '79. Bob Parnass had an excellent article that made the rounds on the interwebs 20+ years ago. I think it was titled "Repair Tips for Bearcat Scanners". I think he mentioned that the Bearcat 300 had a fairly good receiver, but the 350 was a dud.Early 1977 sounds about right for the 210. A few years later for the 250. I've never seen a reference to a BCL, but it wouldn't surprise me if there was one since low band was big, UHF was exotic, and 800 was practically unknown in that time frame.
