best antenna for a pro 95
kc9neq
Illinois
can someone recommend the best rubber duckie antenna for a pro95 that has a bnc connector. i saw some recommendations on this site but i can not seem to find them.
thanks
Dubbin
Findlay Ohio
Depends on what you want to listen to. The RS 800mhz is good for, well 800mhz and the Diamond RH77CA is one of the best all around antennas. Buy one of each and you will be plenty satisfied.
KT4HX
Spotsylvania County, Va
RS stock antennas are known for their less than stellar performance. Most people I know wind up buying additional antennas to focus on a particular portion of the spectrum, specifically, as Dubbin mentioned, the RS800 and the Diamond RH77CA. I would venture to say that the majority here likely replace the stock antenna fairly quickly after a scanner purchase. At least I know I do!
pogbobo
VA
lol i think my stock pro97 antenna is still in the plastic sleeve in the box somewhere ... the RS 800 is awesome :)
Big_Ears
With the stock antenna, I usually need to rotate the radio in order to receicve optimum results. For critical monitoring of the UHF & 800 Mhz bands, I use an old Regency HX-1000 stock helix antenna that's been cut down to a little over 1 inch total length.
hoser147
Grand Lake St. Marys Ohio
thanks
What is it that you Monitor the most? Conventional, Trunked? If ya can give us that info it would help us to help you. If not a State County and City would work.................Hoser
